Hello! And greetings from Finland. Ursäkta, jag talar inte svenska bra.
My problem is clock/thermometer, it is readable only when use flashlight. Bulbs of the clock have to be changed.
I have read british and finnish Renault-conversations and I had to know what kind of bulbs I have to buy.
Someone says that bulb is specialbulb, and other says that bulb is traditional 12v 1,2W T5.
Can you help me?
Renault Megane Break 1999 K4M-700 engine.
Renault Megane 1 year 1999 clock bulb.
Re: Renault Megane 1 year 1999 clock bulb.
I suggest you buy one of each, they are cheap. The easiest way to know is to spend 5 minutes in the car and remove the broken lamp.
I guess you have one of the below, probably the second type:
https://www.biltema.se/bil---mc/bilrese ... 2000032139
https://www.biltema.se/bil---mc/bilrese ... 2000016550
Thanks.
I worked with the car today and replaced the bulb. I had correct bulb in my carage. Bulb it at the first link in previous message.
Problem solved.
Problem solved.
